TakingThe5th wrote:
mkirsch wrote:
Are you saying the X-chock still won't fit on the curb (i.e. right) side?
You only mention the street side, which you said fit fine before.
The X-chocks were interchangeable. When we discovered the problem on the curb-side, we took both X-chocks over to the street-side to verify that we had a curb-side problem and not a problem with either X-chock. Both chocks worked well on the curb-side.
I am asking about *AFTER* they "fixed" it.
You do not mention whether the X-chock will fit on the CURB side after the trailer shop was finished working on it. Only the street side. The street side fit before, so I don't know why you'd even check that.
Though, if the tires are 1/2" larger, they're likely on their way out. I'd replace them ASAP.
