spike99
May 14, 2013Explorer
Yes. Replacing "at max weight edge" 3500 lbs axles with higher rated axles is a great idea. Actually, it's a very smart idea. Remember to measure Hub Fact to Hub face and if needed, order axle 1" longer (giving 1/2" wider on each side). If wondering, my one trailer's factory axle tires would rub. I replaced axle with higher rated axle that was 1" longer and it worked great. No more rubbing (because the factory axle was too short).
For hub face to hub face measuring, surf: - click here -
Also remember that going up size axle haz stronger electric brakes as well. Having more brakes than needed is a great thing as well.
Hope this helps.
Hope this helps.
44,071 PostsLatest Activity: Aug 16, 2026
