Ralph_Cramden
May 15, 2018Explorer II
Lynnmor wrote:Ralph Cramden wrote:
When I think back to the days of the daily driver with front drum brakes and roller bearings, I wonder why people were not obsessed with greasing bearings every 200 miles, especially on something they drove 12K, 20K, or 30K miles or more per year and depended on to get to work or take momma to the hospital if she was ready to pop one out. But with a trailer for some reason, greaseobearingphobia seems to be the norm, at least on RV or camping related boards. More power to you if you want to self develop OCD over bearings, I'd rather go fishing and drink cheap beer. The cheaper the better.
I'd rather be a responsible adult and recognize a problem and correct it. I still have a 39 year old van with the original made in USA bearings that I repacked three times. I also have a travel trailer that the cheap junk Chinese bearings failed in one season. My suggestion is to not give advice if you cannot or will not properly explore the issue.
Hmmmmm, still running the OEM bearings on our 2017 Rockwood, about 6000 miles in the last 3 seasons. I pulled them when new, cleaned all the OEM grease out and repacked with Lucas Red N Tacky, then used EZ lube twice since.
The previous 2013 Keystone we had for 4 years now resides in Atlanta GA, I talk with the buyer online on another board quite often, still the same OEM bearings. I used the EZ lube, he uses the EZ lube.
Prior to that had a 2011 Aerolite, same deal used the EZ lube. I'd guess over 12K in 3 seasons.
A small fleet of equipment trailers (7) out on jobsites as I type. All have the OEM bearings and I have no clue where they were made, nor do I care. Most of those trailers have EZ lube. And for kickers all are running whatever Chinese brand ST tires they came with, or whatever the local tire guy had in stock when we needed new ones.
I believe I have properly explored the issue....which is a non issue except on an RV related forum.
