LosAngeles
Sep 30, 2019Explorer
Did I forget anything? ordering a new Hallmark pop up camper
Did I forget anything? About to order new Hallmark pop up camper
Hi all! I am about to order a new Hallmark pop up camper.
Hallmark has been really great at answering my many questions but i thought i’d reach out to the nice people here to double check…. before i place the order.
9.5 foot base, Everest build. (yes, they will do this)
Nova Kool 2 Way Refer AC-DC 7.5CU FT
ALU CAB 270 degree Shadow awning (really want this model - no leg to whack)
Extended “cab over” bed…. with side of the bed storage cabinets
4 x 180 solar panels = 720 watts Grape solar panels.
Cooktop 2 Burner w/ Piezo Ignition
Interior small sink, drains to small grey tank on drivers side.
Mini shower stall (drains to bucket below)
MaxxTraxx and locking exterior mount.
two x Battery Battle Born BB10012 12V Lithium
Victron BMV 712?Battery Monitor w/ Bluetooth Lifepo4 Ready
60A Mini Lithium Ion Power Center Black PM4060LIK
External shower - Bullfinch
Combination hot water heater and heating unit / LP powered MFG. by Truma (PLUS)
FREEDOM XC-2000 XANTREX INVERTER / CHARGER
dual distribution centers
Tork Lift Tie Downs
Victron SmartSolar charge controller MPPT 100/30
External Solar Panel Zamp Plug Roof/Side
Lagun Table Leg to make inside dining table more flexible.
woven grey floor mat, with snaps
stereo delete (not getting the stock stereo)
no graphics “naked trailer” (we prefer the plain look)
Maple Wood Cabinets
TorkLift tie downs (the only option that will work with a current F350)
-> -> * plus a few things that I still need to get added to the existing quote: *
rear Hallmark Storage bins (to fit Honda 2200, etc)
Low pressure propane quick connect on exterior - for stove, and Campfire In A Can - back passenger side.
Mach8PLUS Hvac
metal work on the roof to 100% cover wires that connect to the roof solar panels. (to protect from UV)
Mounting the stock Ford tailgate camera on the rear Hallmark bumper
Mounting a $400 3rd party AUX camera up high on the rear of the Hallmark (always on if I select AUX camera on the Sync 3 system)
Hardwired 110v surge protector - Progressive EMS-HW30C
rear exterior hand hold (for getting in and out)
maybe the rear fixed ladder? (unsure of cost) tho no plans to go onto roof…. though the ladder would make cleaning snow and dirt off solar panels much easier when out camping. No good space to carry a regular loose ladder
small single wood step, just below over cab bed, to make getting in and out of over-cab bed easier.
clear rear Hallmark window, adjacent cigarette power outlet, that is switched with a switch there. snap on privacy cover for this rear window.
Extra layer of fabric added inside, (small patches) where hinges rub against the fabric, as long term protection.
Are there 10 LED lights in interior?
Likely add some $50 LED Reading Focus Lights - unsure where??
Maybe get slack on the internal water line that runs to the outside drain valve (and also the outside shower) to make any future repairs easier. (I hear the outside water valve from the tank drain breaks easily, especially in the cold)
Maybe have them add a rubber bumper to the front of the camper, in case it slides forward a bit in the truck bed.
is one Power Roof Fan 3-speed w/ In & Out included? (i think it is)
Differences between rear exterior Ladders : narrow, full, OR off set ($125 any option)
Should I do Bed Line X? Not bother?
Thanks for any and all good thoughts! :-)
Tork Lift Tie Downs
Maple Wood Cabinets
Mach8PLUS Hvac
