Luminajd
Mar 20, 2016Explorer
73guna wrote:
Lets not jump to conclusions and assume this is bad lifters.
While its possible and they are known for this start small and work your way up.
Is your oil pressure low?
How is your oil maintenance on this engine?
Do you use proper weight oil and a quality filter?
Could be an exhaust/exhaust manifold leak?
Is the noise constant, change with rpm, engine warm/cold?
I would get an automotive stethoscope and try to narrow down where the noise is coming from. Could be the lifters, injectors, exhaust leak, transmission. Poke around and see what you find.
Maybe change the oil filter and add a quart of trans fluid and drive it for a few hundred miles and see if the detergent in the trans fluid will remove some built up sludge, then change the oil and see if the noise dissappears.
Spend $50 first, it may be something as simple as what I said. Dont automatically assume it will be a $3000 repair.
does it sound like these?
https://www.youtube.com/watch?v=vyhl7N6WVbI
https://www.youtube.com/watch?v=4RecrxxLT4s
Oil pressure is fine
Always changed oil on time with the right oil/filter
I reached out to my brother, who is an experienced mechanic (who I hadn't thought of before because he is a super busy guy), and he's looking into it for me.
I drove a 2500 yesterday just to check it out and I could deal with the ride, but it didn't have the remote start and heated seats Ive come to depend on (I live in Iowa and am a baby in the cold). When I search online, it is hard to find which trim models these features come standard on, DO they come on certain trim models in 2500s, RAMs, F250s, etc? (in case I decide to trade up)
44,056 PostsLatest Activity: Jan 12, 2020
