valhalla360
Aug 23, 2020Navigator
On diesel boats, there is often a t-handle that you pull which cuts off fuel to the engine and it's the standard way of shutting it down.
Doesn't help if it starts sucking oil into the cylinder but it will solve an over-fuel situation.
Basically if a diesel engine has fuel and air getting into the cylinder, it will run, so you have to cut off one of those (gas engines also need spark and that's simpler to cut off)
44,071 PostsLatest Activity: Aug 16, 2026
