noteven
Aug 23, 2020Explorer III
A diesel is an auto or compression ignition engine. It only needs sorta vaporized or gaseous fuel and air in approx 15:1 ratio to run...
Nowadays this is usually the engine aspirating lube oil through a failed turbo.
A positive air shutdown can save the engine and also prevent a fire or explosion if the engine is breathing external vapour or gas.
These can be automatic or manually operated.
They are also a great theft deterrent. It no start with the shutdown valve closed.
Used on pretty much ever Diesel engine in the oil and gas industry.
