dodge_guy
Aug 23, 2020Explorer II
if the injectors stick open it will do just that. I have seen a couple of injectors at the beginning stages of failure on that particular year Cummins. if you revved it, it would continue to rev for about 5 seconds and then settle back down slowly. the injectors I believe got weak from the tune that was in it. I found 3 bad injectors, but recommended all 6. That fixed the truck. Not sure if that`s the same issue here.
