was_butnotnow's avatar
Aug 24, 2013
Diesel exhaust smoke
OK so I've got a 2003 Chevy Duramax with about 135 K miles and it now has blue to dark smoke when starting or at idle. I don't see smoke at road speeds unless I really punch it.
So now my question... A RV park owner noticed the exhaust when I pulled in to dump and asked if I had replaced the fuel filter as he noticed the blue exhaust. We have replaced it several times and WONDERING if there is anything like a tune up or other measures that can correct this issue. I get good milage and not other adverse effects with this truck.
I just assumed this is what happens when a truck gets this many miles on it or can this be corrected?
I see the big 18 wheelers who blow smoke so was not too concernend but would like to know if a tune up or something can be done to restore my Chevy to not do the smoke thing. Any thoughts.
  • At 135k it shouldn't smoke. Thats just broke in. Does the dipstick show oil missing?
  • Check your exhaust piping, you can get that condition if you have crossover pipe small leak prior to turbo inlet. Don't know if that is your problem but worth a look, especially if your still running on original 10 year old exhaust piping
  • Don't overlook valve guide seals letting crankcase oil seep into the combustion chamber. I may be wrong in this theory applying to Diesels but that is what we look for in gas motors. I had the blue smoke coming from my gas car and replacing the valve stem seals cured it.
