NHIrish wrote:
Since you asked. I use Stanadyne performance formula. I wish I didn't think that it was necessary, but I use a fuel additive for the following reason.
According to the injector manufacturers (see link to their common position statement regarding diesel fuel), the problem is that US diesel fuel does not meet the lubricity requirements for their injectors. Despite that, these injectors continue to be used in our trucks (Ford and Chev...not sure about Dodge). In fact, they estimate life of injectors to be considerably less in vehicles using US spec fuel. The primary issue is fuel lubricity and scar ratings, although cetane ratings can also be problematic.
The following is a quote from the Bosch et al common position statement regarding fuel requirements for diesel engines. Please note that this is a statement issued by the manufacturers of the injectors used in our vehicles...not just some guys opinion on the internet. Why this isn't more of a widely reported issue, I don't know...but to me there is a design incompatibility here.
"Lubricity: It is essential that the lubricity of the fuel as measured by the HFRR test specified in ISO 12156-1 meets the requirement of a wear scar diameter not greater than 460 microns. In addition, it is recommended by the Diesel FIE manufacturers, that “first fill” of the fuel tank should be with fuel with
good lubricity characteristics (HFRR < 400 µm) in order to guarantee good “run-in” of the injection system components. The US diesel specification (ASTM D 975-09) includes a lubricity value of 520 µm maximum (according to ASTM D 6079). It is expected that the useful operating lifetime of any mechanical component will be adversely affected by fuel with a lubricity exceeding 460 microns."
The entire position statement is available at the following link;
http://www.globaldenso.com/en/topics/091012-01/documents/common_position_paper.pdf
Because of that, I use Stanadyne...a product made by one of these manufacturers.
What REALLY convinced me to use a fuel additive was owning a 6.0 ford diesel and having FORD tell me to use one. Amazing the difference in smoothness of the engine running an additive in that engine.
So, for me I do and that is why. Every tank. Injectors are a thousand bucks a pop...cheap insurance.
...x 2...but many here will not believe what you posted...Your comment on the Ford and GM fuel injection systems is quite accurate but the real problem is not with the injectors. The problem is with the High Pressure Fuel Pump...known as a Bosch CP 4.2 pump. As you posted, these pumps are designed for 460 scar fuel. The US fuel standard is what you posted...but Canadian fuel is the 460 scar standard. Early in the Ford 6.7 HPFP debacles, the Canadian failure rate was considerably lower than the US failure rate...No wonder Ford sells a lubricity additive, PM22A, and highly recommends its use...
But they still take the position that the pump is fine and still deny all the warranty claims on HPFP that they possibly can get away with...
Meanwhile, GM uses the same pump...does not sell or recommend a lubricity additive...and warranties all HPFP failures...Good for GM
Shame on Ford...
Regards
