Racine96ExplorerNov 22, 2013Diesel mpgQuestion: those of you who use a diesel truck to pull an RV, what kind mpg do you get when you pull your RV?
sclarkExplorerNov 22, 20132013 Ram 3500 pulling rig in sig. 11300 lb 5th wheel. 12.7 at 60 mph. 20 empty at 60. A bit better at 62 mph. Aisin transmission.PA12DRVRExplorerNov 22, 2013Based on on-board computer (not what it took at the pump):2006 F350 with 6.0 engine and 4.30 gear ratio, towing 38' KZ Escalade (circa 16,000#'s): Highway towing at 65: 9.9 - 10.2 mpg.Without the trailer, it jumped all the way up to 13 mpg!notevenExplorer IIINov 22, 201306 5.9 Cummins, 6spd manual.15000lbs 3 axle 5th wheel trailer x 13ft high x 39ft long10 - 12 mpg USWill happily do 8-9 mph in wind.0 mpg idling.biggriggExplorerNov 22, 201300 Excursion PS with 30' trailer. Usually about 12 mpg. Sometimes 11 mpg.rgoldingExplorerNov 22, 2013Just back from a Fall Florida trip and averaged 11.4 mpg, traveling 60 to 65 mph pulling a Artic Fox 30U with a 2009 Duramax and Allison transmission. Very pleased with the equipment.APTExplorerNov 22, 2013My friend pulled my TT with his 2012 Silverado dually and got about 12mpg @ 72mph. Compare that with 8-9mpg @ 65-70mph for my 6.0L gasser.2-MTnestersExplorerNov 22, 201304.5 Duramax LLY all stock, Pulling a 38' 15,000# 5er, 9-10 mpg.Old-BiscuitExplorer IIINov 22, 20138000# truck.........14,000# 5th wheel (13'3" wind sail)4 speed auto.....4:10 rear end (5.9L CTD)10.5-11.5 mpg 62mphgoducks10ExplorerNov 22, 20132012 Ram 2500 CTD pulling a 9000lb 5'er. 10.5-11.9 depending on flats or mtns.clubhouseExplorerNov 22, 2013Stock '07 LMM Duramax pulling ~6200 lbs 30' TT 12mpg. I generally dive 60-65
Related ContentFifth Wheel/Diesel mpgMPG with different diesel fuel brandsGMC Sierra 3500 diesel dually MPGTowing MPGCr@p mpg
