Gulfcoast wrote:
2006 Cummins 5.9 - 150k miles.
I know nothing about this 5.9 that I just bought, except it really runs good.
I've always used Delo 400 in diesel engines, what do you prefer and why?
Thanks
Your current crop of diesel engine oils are now API CK4 oils and some changes have been made and some oil brands have taken a different approach when designing and marketing their oil. Some are oils are only rated for diesel engines(which are the ones I recommend) and some are diesel and gas engine rated (which are the ones I don't recommend). In addition the CK-4 specification removed the flat tappet valve train wear test requirement.
For your engine I would recommend Rotella, Valvoline Premium Blue or Motorcraft diesel only oils since the ZDDP anti wear additives are still above 1k ppm and these oils are only diesel engine rated and can be easily purchased at just about any store.
I would not recommend Delvac and Delo since they are now dual rated for both gas and diesel engines and the anti wear ZDDP have been reduced to ~800 ppm which allows them to be used in gas engines.
Whichever oil you choose be sure "NOT" to use any API FA-4 oils.
