Fisherman
Nov 09, 2017Explorer
joe&julie81 wrote:
Saturday morning I was fueling my Dodge Cummins and was topping it off for the first time in a good while when I heard fuel splattering on the concrete underneath. I thought "oh no" I'm leaking somewhere! I didn't seem to have a leak in the tank itself so I went on with my relatively short trip, with no further issues. Maybe I just overfilled it and it came out the spout, but I thought it was coming from behind or below that. Maybe a venting issue? Is this nothing to worry about or should I investigate deeper?
I believe you have the "no fuel cap" filler hole, just insert the nozzle, right? Well there's another flapper door below the first one and in between there's a drain hole should any water(rain or over zealous pressure washing) happen to make it past the first one. If you read your manual, (you did that right), it also says to wait about 5 seconds before removing nozzle. You went beyond overfull.
Here's a copy and paste from a RAM site:
I had this same issue when I first got my truck, the dealer inspected it, they even cleaned up all the mess that was left from the leak. (except for my garage floor that is.....lol)
They gave me a copy of a notice from FCA explaining the problem with pictures.
There is a drain hole above the 2nd flap. So you have to keep the pump nozzle all the way in - keeping the 2nd door open - after you finish filling the tank with fuel, for at least a few seconds to make sure all the fuel drains in.
I stopped jamming my tank full and by leaving the nozzle all the way in and shaking it a couple of times before removing, I haven't had this problem again.
Is kind of a pain in the ass.
I guess it is a good safety in case water gets by the main fuel door, at least it wont go into the tank. But it does make a hell of a mess when it is fuel leaking thru.
