Grit_dog
Sep 20, 2022Trailblazer
JRscooby wrote:Grit dog wrote:
As much as you would hope Creepy Joe and the rest of the govt is able to monitor and control your life, fortunately it hasn't come to that yet...
But I'm sure as a truck driver and self proclaimed mechanic, you've "never" turned up the pump on a mechanical diesel, or in any way modified anything you've ever driven that would make it 1 bit less "safe" for the environment or anything else.
As for turning up the pump, Yes, I have done that, and going back decades. But does replacing the 55 injectors with 70s, adding turbos to the buzzin dozen add more pollution? (Got about half MPG better running meat from Ks to east coast, so I doubt it) When I bought my last truck, the 3406E was factory set at 475, but was do for overhaul. When I took it in, I handed the Cat shop the EMC off the wrecked 1, that was factory set to 600. The shop warned me about the transmission not rated for that much torque so cut back to 575. (Still had to watch trans temp if approach WFO in overdrive.) Plus I set NTC Cummins to the most I could depending on turbo/intercooler. But 1 major difference IMHO; The production dates where between '67 and '95. They complied with all emission regulations at the time!
BTW, I did retrofit PCV to a '56 Old, '57 Caddy, and several pre-'63 Fords and Chevys, which I'm sure did reduce pollution compared to the factory installed road draft tube.
Atta boy! I knew you were a gear head at heart!
And no criticism from me for you being a “responsible” person with respect to what you wrote above.
BUT, and this will be hard to admit, when you were a gear jammin trucker back in the day makin the wheels spin faster to put more meat on the table, I’ll go out on a limb and say that you would have done what it took to protect your interest if you had a truck sitting on the side of the road waiting for some repair to an issue that was seriously affecting YOUR bottom line and the fix was a die grinder and a programmer.
ICBW but I bet your views have become more altruistic since then…
