shadows4's avatar
Jan 15, 2014
Diesels and cold weather
I would like to know if any of you cover the radiator of your trucks? I have a 2003 F350 with a 7.3L diesel engine. This has to be the most cold blooded truck I have ever owned! The biggest problem I have with the truck is that if temperatures get down to the twenties or lower it will not run right. It will,start just fine, but the turbo will not develop any boost until truck is completely warm. Couple of weeks ago it got down to single digits. Drove about 20 miles at hwy speeds and It never did develop any boost.
I guess what I need to know is would covering the radiator help or not? Thanks, John
  • KD4UPL wrote:
    My '05 Duramax has never failed to start and run smoothly even in negative temperatures. I owned it for 3 years, never parked it in a garage, before I discovered it even had a block heater. The cord was hidden by GM so well I just never saw it. So, in those first 3 years of sitting outside all winter it always started just fine with no block heater.
    For comparison, my company's work truck is an '03 Ford with a 6.0. It doesn't want to start very well even inside the shop where the temp is 45 degrees. After it does start it runs rough and has very little power for the first 5 miles or so. I was really surprised at the stark difference between the two when I started driving it.
    Didn't think it got cold in VA. Think they mean like zero or below. In WY @ 20 below it was a problem with the 7.3 diesel. Used block heater and diesel additive.
  • I use the grill cover on my 2002 GMC diesel in the winter .
    the radiator is so big that the truck does not get above the quarter mark in the winter .
    i have driven with the grill cover on at 50 degree temps on long trips and the temp guage still does not go above the halfway mark .
    I rarely plug in and only when the temps are below 10 below zero fahrenheit .
    this 12 year old diesel has not failed to start since new .
    i have made the switch to the AGM batteries in the last couple of years.
  • My '05 Duramax has never failed to start and run smoothly even in negative temperatures. I owned it for 3 years, never parked it in a garage, before I discovered it even had a block heater. The cord was hidden by GM so well I just never saw it. So, in those first 3 years of sitting outside all winter it always started just fine with no block heater.
  • Are you plugging it in overnight?
    Both of my 7.3's liked to be plugged in. They warmed up much quicker when plugged in.
  • if it don,t have a block heater get one , the oil runs the turbo, a blanket won,t help. on my 96 diesel it came with a block heater the cord was buried up front by the grill.
  • When I had my 07 Classic Dmax, I always installed the winter front in late fall, I always plugged in the block heater after -15C and used Amsoil 5-40 Diesel oil. Never had a problem through 3 winters, and it gets cold up here....
    I don't know enough to speak to your boost problem.
