Golden_HVAC
May 15, 2014Explorer
My guess is the curb weight of the F-450 pickup bed truck has a higher curb weight than the F-350.
Be sure to check the rear axle ratio's because the F-450 normally has a lower rear axle ratio, leading to higher engine rpm's at at any given road speed in a certain transmission gear. I would not want the engine reving up more than normal, and considering it is a diesel, you want a lower engine RPM most of the time.
Are you planning on towing more than 23,000 pounds? If not, then the F-350 will handle the load, probably have softer springs, and should not ride as much like a lumber truck as the heavier F=450.
You might also consider a special bed truck. You can buy a F-350 or F-450 in cab and chassis configuration. It will have a slightly longer length from cab to center of rear axle, normally about 9" longer wheelbase. Then a specialty bed is installed with compartments to store stuff. It can have the pedistal or normal style hitch installed too.
Fred.
Fred.
