agesilausExplorer IIIApr 28, 2020Differential fluid changeOK this is my first time doing this. I have the correct fluid and I hope the correct gasket. My question is: do I use permatex on the gasket or leave it clean?
Related ContentFord E350 Rear differential fluid changeTranny fluid changeBrake fluid change?Differential fluid thoughts/recommendations...Rear Axle Fluid Change Differential Cover with drain plug.
