agesilausExplorer IIIApr 28, 2020Differential fluid changeOK this is my first time doing this. I have the correct fluid and I hope the correct gasket. My question is: do I use permatex on the gasket or leave it clean?
Cummins12V98Explorer IIIApr 29, 2020Remove the cover!!! You can inspect and wipe out and sediment at the bottom of housing.
Related ContentFord E350 Rear differential fluid changeTranny fluid changeBrake fluid change?Differential fluid thoughts/recommendations...2006 Damon (Ford F53) differential fluid change madness
