klr650goldwing wrote:
Sorry for the delay on this report. I picked up the truck and 5er last Saturday. We were running an '04 SD V10 CC SRW LB 3.73 as our tow vehicle pulling a 10,000 lb 5er. The truck did okay here in flatland country, but even on the flat it shifted down often. It seemed like even the slightest rise would bring on a downshift. That concerned me because in less than two years we will retire and head out to see ALL the national parks. Traveling up ANY mountain, I thought, would put tremendous strain on the transmission. So we had the differentials changed to 4.56.
On the drive home the tranny shifted down very seldom. Now, granted the drive home is very flat, but still, the difference is amazing. The truck has significantly more power than it had before. It is much more enjoyable to drive now.
Prior to the change 70 mph produced 2000 rpm. Now 70 mph produces 2450 rpm. Driving the truck without the trailer the increased rpm is not the least bit annoying.
So far, I'm happy with the change.
Delay, heck. We're lucky you came back. Glad to hear you like the change. I wonder if my buddy wouldn't also like the change on his 2000 F-250 V-10? He went from a Dodge-Dakota-sized 5vr to a larger 11K 5vr and after the shock, he has lamented the loss in performance ever since. You wrote some convincing testimony to better performance.
I'm satisfied with my V-10 3:73 Excursion only pulling 8K, and we do use it for winter passenger service on trips to Minneapolis, so I worry that my 13-14mph might suffer with other gears. On the other hand, I can only hold OD during low wind conditions towing on flat roads such as I-94 in ND. I usually try to pull at 60 mph. ND does have a 75 mph speed limit, but non-towing I usually stick to 70 anyway, like Minn.
Please pardon a little deviation here:
I see you have several bikes like I do. Most of my experience in gearing changes has been sprockets. I first had a (purple?)
300(305) Dream that came in a basket and sold the same way. Besides small missing parts, the buyer ended up putting a new crank in it.
Sample:
One other possibly of note to you is a
1981 CB900c 5 spd which has a dual-range sub-transmission that converts it to shaft drive. The "low range" gives it a lot more zip with ten speeds altogether. This vintage "touring" bike is extra heavy with optional bags, trunk, full Vetter fairing, so the low range is handy at times. I made a trailer for it but DW refused to consider it. The early "touring" options were shared with the early GoldWing at the time.
"Naked" sample:
Another is a pair vintage '66-'67
Honda 305 Scramblers. One is complete except missing the original front fender. The other was my first dirt bike and I had two rear tires/wheels (w/sprockets) for it, on-road/off-road. On the road, it was geared so tall, I had to occasionaly shift to 3rd on a hill. But the snappy large dirt wheel/sprocket topped out at 60 mph off-road at somewhere around 9 grand.
Sample:
None of these bikes are currently running. All the insurance and tags kill me. But... ahh the memories.
Just passed :( , on a 2008 Yamaha WR250R, a sort of miniature version of your KL650.
Good luck on all your journeys.
Wes
