myredracer
Sep 16, 2015Explorer II
The photo shows what I did in a previous TT for a drawer under the bed storage. I cut out a square of the luan plywood using a sharp utility knife. Made up a frame from oak and the drawer box from cabinet type plywood (have table saw and chop saw). This way I was able to size the drawer exactly as needed to suit. Never would have been able to obtain a similar sized door (or drawer front) from the RV manufacturer anyway. Stained the oak frame to match the rest of the factory cabinetry and it looked pretty close.
You could do the same to make a door or to make a drawer front. I like the idea of drawers as the space becomes more useable and efficient. I used Nape & Voght stay-close RV drawer slides but any other ball bearing slide will work.
I've purchased drawer/door fronts for our current trailer from our dealer but they sure aren't cheap. I had some made up by a cabinet shop on our previous TT and they were even more expensive than from the dealer.
I like to make things look like they came from the factory. If not fussy, you could possibly find a stock door that will work at HD or other cabinet source. You should also be able to order cabinet handles from your dealer to match existing.
