- mfifield01Explorer
gregrc75 wrote:
That's awesome. Thanks.
I see you have a Keystone. You can order a lot of items for Keystone trailers from this website. Anything from cabinet doors, fabric, matching laminate, windows, etc. In the drop down menus enter your trailer model and year. Find a cabinet door that already is in your camper that would fit as a dinette door. Order one or two of those depending how many you need and use it for your project.
Trekwood - gregrc75ExplorerI see you have a Keystone. You can order a lot of items for Keystone trailers from this website. Anything from cabinet doors, fabric, matching laminate, windows, etc. In the drop down menus enter your trailer model and year. Find a cabinet door that already is in your camper that would fit as a dinette door. Order one or two of those depending how many you need and use it for your project.
Trekwood - camp4everExplorerI ordered mine through the dealer/Keystone.. I ordered the door that is under my stove, it was a perfect fit..
- dwayneb236Explorer
wannavolunteerFT wrote:
I saw somewhere (probably on here or in Trailer Life Magazine, where the owner cut out the opening using drill and fine saw, then mounted the panel they cut out into a wood picture frame. They added some 1x2 supports inside the storage area. The wood frame made the door look like a panel door and was something sturdier that you could hinge to opening (with 1x2) backing using wood screws. I was planning to do that to my Mom's class C, but she decided to sell before I got it done.
This is what I did. Just make sure the cuts are clean as possible. I just used some 1X2 to frame mine out. It's been a huge help too. The access under the dinette is so simple now. And it matches of course...
- Opie431ExplorerForty years ago when my father did the same thing he made his own doors and finished them to go with what was there.
- mobeewanExplorerMy dealer took 6 months to do warranty work and install an add-a-room I purchased with the trailer. The warranty work was so crappy I contacted the manufacturer and made an appointment to drop it off. When I picked it up I asked about purchasing some cabinet doors, hinges, screws, pex tubing (for plumbing mods) & matching paneling (to make shelves for the cabinets that were 18 inches inside). I picked out the cabinet doors and they brought out everything else to the trailer and loaded the paneling. When I asked how much they said no charge. The larger cabinet doors I picked out were a perfect fit for the dinette seat ends.
SoundGuy wrote:
I should have looked through your gallery earlier. You have done a lot of things I plan to do. I just ordered a Blue Sea mini switch for battery/batteries.mfifield01 wrote:
If so, where did you get the panel?
Your most obvious source is your trailer manufacturer, the sooner the better as interior decor changes frequently. Measure for the size you need, check out a few lot models at your local dealer for the door you need, then have them order it as a replacement part. I've done this with every trailer we've owned, in the case of our current rig adding cabinet doors to the end of the bed platform.
- D_E_BishopExplorerI went to a salvage/surplus yard and found two cabinet doors of the correct size. Built the drawers and cut out the panel with a flush cut cabinet makers saw. Easy as pie, no fuss no muss.
Photos on request. - wannavolunteerFExplorerI saw somewhere (probably on here or in Trailer Life Magazine, where the owner cut out the opening using drill and fine saw, then mounted the panel they cut out into a wood picture frame. They added some 1x2 supports inside the storage area. The wood frame made the door look like a panel door and was something sturdier that you could hinge to opening (with 1x2) backing using wood screws. I was planning to do that to my Mom's class C, but she decided to sell before I got it done.
- SoundGuyExplorer
44,052 PostsLatest Activity: Oct 29, 2025
