At the edge of our u shaped dinette is a hard board to keep the cushions from sliding off. Problem is it hits your leg each time you sit down or get up. Does anyone have any suggestions for padding th...
I bought a 2" rubber mat, cut in two and put one under each cushion and no more problem! Measure the width & length and buy one rubber pad. Then cut in half. Good Luck & Drive safe!
