myredracer wrote:
wmoses wrote:
How much wobble is too much? ALL designs will have wobble to some degree, ...
Afraid I have to disagree on "all". Our double Lance legs do not have any discernible movement plus we have a factory solid wood table that does not move or flex. The Lance flanges and leg are machined with a tight tolerance. Maybe with a lot of force you'd see some movement, but by that point, the floor would be flexing.
Note that I said "to some degree" - that justifies the use of "all". I also suggested that one man'w wobble might be imperceptible to another. Unless you have a table with 4 legs at the 4 corners, and have a robust grillage all across the table top underneath, there will be movement. :D
