You can do a couple of things. The first is to go to your RV dealer parts department and buy some high dollar stainless steel small mesh screens.
The second is to go to your local hardware store and buy some 1/8" mesh hardware. Cut them to fit the openings. if you don't have snips to cut it and can not borrow a pair, Harbor Freight sells them cheap. When you finish throw them in your tool box. Cut the hardware cloth to fit the openings. Take the cover off of the AC and install the screens from the inside. You can drill holes and install them using pop-rivets, or a hot glue gun will work just as well.
