trail-explorer wrote:
Crumm wrote:
3. The slide in tubes on the frame mounted tie downs are very sloppy. When the fastguns are tight they don't slop around but without the camper on they must be removed or they flop around and rattle. Why not use tube that slips in with a little closer tolerance?
I would guess they can't, because the tubing isn't made in size that fit tightly in to each other.
Not in that thin of wall but there is closer tolerance tubing. I have built flat beds with stake pockets and other projects that used tube in tube and I have found sizes that fit snug.
