Crumm wrote:
On a side note why do the tie downs extend front and back from the tubes which causes them to twist the tube while pulling up? Why not use the hole in the center for a direct pull?
They extend front and back to give the user various points to attach the camper to. Allowing the turnbuckles to pull/hold the camper in the correct direction. The die downs ar designed for the truck but not necessarily the camper. Different campers will use different connect points.
(I think I got this info from one of their videos.)
Ben
