Depending where you buy your FastGuns, you may still get the older handles. Once the stock gets into the distribution channels, it depends how fast the retailer turns over inventory. I got the older model handles on the short range FastGuns when I replaced my long range models. Since I was familiar with the older handles, I am fine without the newer style. As far as I know, the model number did not change when they changed the design (which may put off some buyers) - Maybe TL should suffix their part numbers if there is a revision?
