ticki2
Feb 20, 2019Explorer
By the look of those pads they are either of poor quality or there is too much heat . I lean towards the latter . Brake calipers are notorious for sticking on their slides from road grime or rust and even ill fitting pads from New. After. Compressing the piston the caliper should slide in and out by hand . If it doesn't it will not open enough when you release the brakes and cause excessive heat , not enough for brake drag , but enough for heat . Like constantly riding your brakes .
44,071 PostsLatest Activity: Aug 30, 2026
