Camper_Jeff___K's avatar
Feb 20, 2019
Disk Brake Pads With Heat Cracking
Link Goes Direct To Video Segment Showing Brake Pad Wear.
I had my Truck Camper mounted on my F-250 for a couple months. I was in Arizona, Nevada, Oregon, Washington, and did drive a few steep hill grades between Seattle and Quartzsite and places between. I suddenly heard metal on metal sounds coming from my brakes. I went ahead and changed the front pads finding the inside front left pad material had sheared off the metal plate it was supposed to be attached to that goes in the caliper. These pads were only about a year old on the truck from when I made the same trip last year. It just seems a little quick to go through a set of pads.
I'm wondering, Has anybody else had experience with having their truck camper mounted on their truck for extended periods of time and had fast brake wear or pad failure like what I show?
  • I fought braking issues on my 35’ 20,000# over loaded, under designed 16” wheeled 97 F 53. Rebuilt completely; OEM calipers, slides Ford grease, hoses, high temp fluid, rotors. Still problems.
    They ended when I started driving like I didn’t have brakes. Big gap when in traffic, second or third gear downhills, etc. I hated being that guy on downhills but losing your brakes is not fun.
  • trail-explorer wrote:
    Kayteg1 wrote:
    1 years is mean less.
    What exactly does the phrase mean?
    Meaningless. Time doesn’t matter, mileage and use do.
    Sometimes you have read between the lines.
    Pretty common when that person posts. Some of the words are missing or not even correct, so it makes it hard to understand what he/she is saying.
  • Good we don't have brake problems and can concentrate on google speller :D
  • I eye roll to mice elf all the time::R
    Looking for a quite generator.
    Can’t stop, having break problems.
    We go their allot.
    They lost there dog.
    We like meetloaf to.
  • When a brake is dragging....can't you smell that?...I just replaced a rear caliper that had seized up..not the guide pins but the caliper piston broke and seized up...SidecarFlip has this down....good write up.
    Depends how much temperature it generates.
    When I was using F450 for equipment hauling - infra red thermometer was my big friend. Not only tire temp would indicate lower pressure, but checking the brakes temp would indicate any problems with them, while occasional check of differential temp was not bad idea.
    20 seconds spend at rest stop could avoid lot of problems down the road.
    The laser-pointed thermometers go for $10 at HF sales. No excuse to not carry one.
    With new truck and TPMS I don't do it anymore, but when truck ages, the thermometer is still handy.
  • Defective auto parts? New in the box? Naw, NEVER had that happen to me! LOL! :B
    Try a different brand. Try a different seller. Don't be afraid to hit up Summit / Jegs / RockAuto instead of your local Shucks/O'Reilys/NAPA/etc. Finding a knowledgeable person at the local auto stores is pretty tough. You may not find what you are specifically looking for locally and the counter person will try to sell you something that is "the same thing". Yeah, right. You are smart do do some on-line research, including here on this forum.
    -Eric
    -Eric
    I agree. Cheapest and closest isn’t always bestes.
    I remember in my youth I had a 69 Lincoln (460) that had a leaky water pump. Changing it out was not easy. Ac. Had to be removed and folded back, rad out, fan out, ps out, one bolt that you could only turn an 1/8th of a turn a whack. Meanwhile I’m working 7-10s.
    Found a remanny put it on and like two weeks later, weeping again.
