notsobigjoe
Apr 11, 2017Nomad III
burningman wrote:
Yeah that's too narrow! It'll fit but you're not leaving any room for slight movement or error backing under it. 107" is much better.
Center of gravity isn't as critical as it looks, you can adjust th bottom hoops forward or aft to make the footprint as big as you want.
Wanna know what's ugly? A camper that crashed when the spindly corner jacks failed!
Wanna know what's pretty? Your face when it's SO EASY from now on to load and unload!
I agree it's to narrow and whole heartedly disagree of the importance of COG. The bottom hoops are great but don't do a single thing when lifting and lowering. If it's off center enough either the rear or front jack will lift off the ground. This is what happened to me.
I had to lift the rear jacks up for the stable lift front jack to touch the ground otherwise it would just teeter like this. But then again I was 11 inches off center. so you may have a point.
