I'm pulling a 22 ft TT for the 1st time w/my 2018 F150 2 rear WD. I have a Anderson WDH. Has anyone added air bags to their truck and does it help that much. I have to really tighten the chains to bri...
The chains are supposed to be tight. How much are you compressing the urethane bushing? Should be about 1/4” or so, if I remember correctly. I raise the tongue and truck with the jack to make it easy to adjust the tension nut. I have about 600# on the tongue and have no problem returning the front end to spec. Do you know the tongue weight?
