You gonna end up with a 2011 Trailer which is not all that old... To me that size up to the 24-25 foot length would be the perfect size. Easy to tow and will fit most camp grounds and Natl Forest sites with ease.
If your fixes went well and after a good inspection of all other possible problems you should be in good shape for a long time to come..
What are other 2011 similar TT's going for...
Knowing what you have now is worth alot to you as the next used trailer will most likely have different new problems for you to fix anyway...
AS-IS is just what it means AS-IS... You will be at the mercy of the goodness of the dealer... Some places has the so called lemon-law where you can return it in a 'very short time' after taking it off the lot...
Roy Ken
