agesilaus's avatar
agesilaus
Explorer III
Oct 10, 2018
Do I need a WDH with a 25ft TT
That's being pulled by a 2012 F350 diesel? I think the newer trucks have some sort of anti-sway but so far as I know mine does not. The truck will be heavier than the TT tho. TT 6500 truck 8500
I suspect the answer is yes but want to check.
  • WDH probably not, but away control may be required. I've pulled my moms 24 ft TT with nothing but a ball and it was just fine. I bought a 26 ft TT about 6300 lbs. It tows horrible, needs at least one sway bar, 2 would be better. Have done the weight thing, really don't need any distribution. All this with a 08 F350.
  • agesilaus wrote:
    colliehauler wrote:
    Personal preference, I tow a TH TT that's only 22 foot with a Ford F-350 and the ride and handling is improved with a WDH. My tongue weight is around 1250#.
    What truck are you using?
    He said a F-350.
    Barney
  • Personal preference, I tow a TH TT that's only 22 foot with a Ford F-350 and the ride and handling is improved with a WDH. My tongue weight is around 1250#.
  • That would be one less thing to worry about, thx for the answer.
  • I tow a 30ft trailer with a '17 F250 6.7l without WDH or sway bars. The trailer is under 8k and the truck weighs in at 8200lb. I have a great ride even in the wind. My truck does have anti-sway electronics but I don't think it has ever come on.
  • Yes. Shifting weight particularly back to the front wheels helps braking.
