campigloo wrote:
This is for people who wonder if this is needed. This is also for those who have so much pride in their rig that they advise newbies that a properly loaded and balanced rig doesn't need sway control. Granted, my hitch is not the latest greatest. In fact, it's old school. An Eazlift with 1400# bars and 2 friction bars. Over my life, I have logged over 200,000 miles towing. I am no novice. Last Sunday, traveling I-55 south below Jackson, MS there was a really thick thunder storm ahead. Very dark skies, a 15 degree drop in temperature over a 3 mile span, heavy wind and rain. No big deal; done it dozens of times. After crestng a hill and going past a sudden clearing of trees on both sides of the highway, I got hit by a gust of wind. It was the first time I have really been scared while towing. The 2 sway bars gave me enough time to hit the trailer brakes to pull it back into line. Without them, I am convinced I would have lost control. OTo those who wonder if they are needed, most of the time, no. But this time, they saved major damage and possible injury. Sway control is cheap. In my case, lack of them could have been devastating. My rig is well balanced and is pulled by a very capable vehicle. I just encourage you to eat your pride and spend a few dollars on some kind of sway control. Roll your eyes if you want, but I'm home safe.
I am sorry about your run in with the wind and glad you came out of it ok. You are lucky since you did exactly the wrong maneuver under those conditions.
A heavy gust of wind wants to lift the trailer and it's wheels off the ground on one side. To get those wheels and the trailer back to level again and the forces all more or less equal you need to ACCELERATE smartly and smoothly. NOT hit your brakes.
Acceleration puts a forward force on the trailer thus pushing the raised side and wheels back firmly on the ground.
No sway bar is needed for this and no sway bar will keep your trailer grounded with the wrong driver inputs under severe circumstances.
In addition a sway bar is designed to counteract side to side movement not up and down. When a gust of wind hits your trailer some part of that force wants to push it side to side. But the more resistance to side movement there is will only increase the lift off the ground. This is one area where the untested and a possibly ill designed anti sway system could actually increase your troubles.
The correct driver inputs are the only true defense against these kinds of things. Allowing ourselves to be lulled into a false sense of security by an accessory is a slippery slope.
Also having a well reasoned and scientific basis for a belief or opinion has nothing to do with "pride". Pride has no place in my belief that if your rig is properly set up and loaded you will have no problem with sway. And that you will enjoy towing just as much as anyone without an anti sway system.
