bighatnohorse
Feb 15, 2014Explorer II
Boj300 wrote:
I thought everybody agreed not to exceed the axle rating? If I add a leaf or two (and remove the superspring) and the sway bar i can probably make it ride good but those additions alone will put me at the axle weight limit. Once I add a superhitch and tongue weight, I will be 400 lbs over.
Confused I am.
You have two goals, correct?
1 reduce sway
2 comply with axle ratings
To comply with axle ratings you must have a heavier axle rating or reduce weight.
A gas powered truck, not a diesel, might be the answer to your goals.
44,056 PostsLatest Activity: May 04, 2014
