jimh425 wrote:
wintersun wrote:
The limitation for any truck is the tires. With SRW the maxium load capacity for tires that fit on stock rim sizes are 3750 lbs. or 7500 lbs. for the rear axle less the 2700-3000 lbs. of the truck, leaving a maximum of roughly 4,000 lbs. for the camper and the tongue weight of the trailer.
You can easily put G or H rated tires on the truck that are no larger than stock tires for up to 10,000 lbs. NOTE: I'm not saying to buy a SRW, but the max isn't what you are listing above.
Are there limitations on the G or H tires as far as airing down for offroad use? Like a stiff sidewall that cant be run lower inflated without damage ?
