firemedic1992
Feb 01, 2019Explorer
Why go get a weight-distributing hitch? Simple, it improves safety. With the weight-distributing hitch properly set up, your load is evenly distributed over the axles on the trailer which gives you more stability and control.
It also gives your tow vehicle and trailer a more level ride. A squatting truck and trailer hookup doesn’t just look bad, it can be dangerous. When your tow vehicle and trailer squat, your brakes and steering won’t react quite as well nor will your headlights illuminate the road right in front of you (they will point higher into the sky). Also, minor bumps and dips are amplified and you can more easily bottom out. Finally, the trailer can sway more, as well has have more body roll.
While weight-distributing hitch usage is pretty well known to be low, the reality is it should be much higher. Just because you think your truck can “handle it” doesn’t mean it will when you need it most like in bad weather or in an emergency situation.
If you ever have an accident do you really want to give the other lawyer any advantage as to liability? What would a reasonable person do?
44,066 PostsLatest Activity: Jul 25, 2018
