IdaD
Feb 01, 2019Explorer
mjbenedict wrote:IdaD wrote:
The hitch rating is 1800 lbs, so tongue weight isn't an issue. I wouldn't be too worried about giving it a shot on a ball. Might find you don'd need a WDH and certainly front axle unloading isn't going to be a concern with that CTD sitting up front.
That's most likely 1800lbs with a weight distribution setup. You're probably ok because most hitches are about half that without the weight distribution. That would be around 900lbs hitch weight. My 7500lb trailer fully loaded is 1000lbs hitch weight and can reach 1100lbs so it would be best to keep your trailer empty without the weight distribution.
No, it's rated for 1800 lbs without a WDH.
44,066 PostsLatest Activity: Jul 25, 2018
