Bob_Landry
Mar 31, 2013Explorer
The only conditions that would warrant NOT using WD is that the tongue and trailer weight are below the listed spec in your truck manual, AND if when hitched, the front end of the truck does not rise. If the front end rises, then the trailer has taken weight off the front axle and it needs to be returned to the manufacturers spec. Even in the unlikely event you do not really NEED WD, sway control is certainly advised. The guy that your trailer does not swing over and hit will appreciate it.
44,067 PostsLatest Activity: Jun 03, 2026
