I have a dodge 3500 crew cab with a Lance 1181. Has anyone had any problem with the frame breaking? Both of my rails broken about mid way of the rear seat.
You don’t State SRW or DRW, the SRW in 2009 maxed out at 10,100# The DRW maxes at 12,200# payloads maxed at 3,000# for SRW and 4,750# for a DRW. Dry weight on your Lance is 3,650#, so likely overloaded on either, not like enough to cause the frame to break. Do you drive a lot of rough roads? The frame is fully boxed, do you live in the rust belt, is the frame he’s LT corroded?
