I have been reading all the info and forums since my first post. I have ordered the dodge upgrade kit. The kit changes the way the steering geometry works from a Y configuration to a H configuration. This also requires replacing the pitman arm and steering damper. I also ordered those parts. I ordered Moog upper and lower ball joints. I am getting all this replaced, and will check the hub bearings.
I had to replace my front tires at 30k miles. They both separated ( on my trip to Alaska ), but still had plenty tread. My truck made no noises and drove great with the exception of seeming to pull to the right a little. The second set of tires were wearing to fast, and in a strange pattern. I took my truck for the recall last week, which they said my did not need. I asked for alignment and the then told me about the wear on the components.
I have read enough on this situation to be totally concerned about dropping 5000 lbs in my bed and driving down the interstate at 70 mph. I am going to replace all I need to and add a steering brace. We are heading out west for a few weeks and I don't want to worry about it.
