mkirsch
Apr 21, 2016Nomad II
Perrysburg Dodgeboy wrote:
The oil drain plug on these engines are indented so not all of the oil will drain out of the pan and this is what is discoloring the new oil. With 13 quarts is will not affect the new oil.
Not to mention the oil in the oil pump and oil galleries throughout the engine that do not drain when you empty the pan...
An oil change is never a complete oil change. There is always some residual old oil, but it doesn't hurt anything. If the oil was so bad that it wasn't doing its job before you changed it, you've got bigger problems that changing the oil won't fix.
44,055 PostsLatest Activity: Dec 23, 2025
