KKELLER14K wrote:
Hello everyone!!!, It has been a long minute. I am posting this as a safety issue and I hope the forum will see it this way also. I have an early model Dodge dually, (2002), with a Cummings diesel. This is the issue: the front suspension wears out quickly. Mainly the ball joints, track bar, the drag links, and the two tie rods, which are specific. Take note that if you own one have it checked. The factory used parts have nylon plastic bushings (JUNK). PM me if you want to know what parts to use...this is not an easy fix but if you see the wear, you will do it tomorrow.
Thanks, yes these front ends are quite the mess....
We added a steering stablizer bar which did take the flexing out of the frame. It helped the wandering from side to side going down the road...
For 100% reliability the camper should be taken off and the box filled with spare front end parts:)
