2012Oudoorsman
Aug 10, 2013Explorer
kells81 wrote:
The door list it as something like 6700# but the website VIN Lookup list it as 9600# truck.
Your GVWR, the most your truck can weight according to Ram, is 6700lbs if you have the quad cab or 6800lbs if you have the crew cab.
Your Towing capacity is completely different from gvwr. With 3.92 gears you should have a gcwr of 15,500 which is your truck and the trailer combined. If you have the 3.55 I think its 14000. It looks as if you're a little confused with the numbers. Hopefully this helps you understand them a little better
