Lurker52
Jan 08, 2014Explorer
Dodge Ram 48RE
I have a 05 CTD with this auto tranny. I have read alot about how it can have problems. I have about 123k on my truck. I have owned it since 87k. I fulltime and have put about 10k towing mostly throug...
jsr21 wrote:transamz9 wrote:
No problems out of my 05 Cummins. I have owned it since new and it has been running well over 100 hp over stock since 08. The transmissions are good it just depends on how you treat them. I am embarrassed to say that I have never changed the fluid or adjusted the bands on mine. I am getting the famous shuttle shift with mine but I just shift it manually when this happens. I feel like when I make it to 100,000 (this will be this year)that I will have gotten the life out of it and then a bullet proofed trans is going in.
The key to the 48 is to keep the converter locked as much as possible. It will only lock in OD unless you run in tow haul. Then it will lock in 3rd also. Anytime I hook to something it is run in tow haul.
I bet you a fresh service with ATF4..and only ATF4 will cure your shift issue...these trannys are really fluid picky.
