352 wrote:
thomasmnile wrote:
352: Glad you got what you wanted and that it was cost effective for you. Curious about the single disc TC. I have read much conflicting info about the value of triple disc (and even 5 disc TC's) over single disc in towing applications. Post how the tranny is working out for you, especially when towing.
Hello neighbor. Come on over and take it for a drive. As to the triple disc that is basically used for heavy duty towing every day or racing or tractor pulling. Triple disc $1000 to $1500. Single $375 to $500. The Billet cover single disc is a real upgrade from the stock TC. There is more of feeling the gears as they shift instead of the feeling like a slipping transmission. The new transmission is a night and day difference from the old one. If your transmission takes a bad turn give me a holler and I will line you up with someone who knows their stuff. Also check out my signature or Facebook @ Gail Minor Holton. MANATEES
Thanks. I'll keep it in mind. 48RE is the slush box in my '05 3500. Since we're not draggin' an 11000 pound fifth wheel anymore (now have a TT that's half the weight) I expect things will be OK as long as I keep the fluid changed and the bands adjusted. Only problem (tranny) I've had with it since I bought it used 5 years ago was a tailshaft seal leak. That was a cheap fix.........thank God. :)
