Cummins12V98
Sep 08, 2013Explorer III
6dot6 wrote:Cummins12V98 wrote:
If you want a car like ride get the GM, if you want a truck to do a trucks job get the Ram.
had to shake my head at this one.
Shake all you want, GM always has had a soft ride. I have owned 82 GMC Dually, 86 C20 and currently a 99 Tahoe. I can tell you my 11 HO Dually 4X4 has a better more firm controlled ride than any of them loaded of unloaded. The solid front axle design is much more dependable with either the Ram or Ford over the IS on the GM's.
As mentioned earlier 45 psi should be in the rear tires on any single rear wheeled unloaded truck or the ride will be much worse.
44,068 PostsLatest Activity: Apr 17, 2021
