RDMueller
Apr 22, 2015Explorer
Ok, good - seems unanimous, w/d will help. Next question will be about adjusting it properly. Most of the threads I've read indicate you should remove about 1/2 of the rise on the front end. Since mine is only rising 3/8" without any bars, this seems pretty inexact. Maybe head over to the scales and measure the steer axle with and without the TT hitched, then try to get the weight about halfway between the two numbers?
44,056 PostsLatest Activity: Jan 12, 2020
