- shepstoneExplorer
Retired JSO wrote:
Skip the gas unless you can find a lower gear than the 3.73. My 16, 6.2 can’t maintain 65 with any headwind over 12-15 mph in 5th towing my 25’ W&P at 9,200 lbs. iI drive in 5th most times towing but a headwind is like putting on the brakes.
This is so true, the 4:30 gearset would be a good choice, headwinds blowing against a large frontal area make a huge difference. - burningmanExplorer IIHe forgot to carry groceries home every other week in it.
My ‘55 Chevy sits in pieces in the garage for years at a time. It looks as good as it did 30 years ago, but it’s always kept warm and dry. I sure wish I had room to keep my camper in there too! Given the choice, the camper loses... - Grit_dogNavigator^ Only if it has 3.31 gears.....they tow better!
- blt2skiModerator
4x4ord wrote:
An f150 is quite likely a good choice for someone wanting to tow a 10000 lb trailer with a gas engine. If I wanted more truck than a f150 I would buy a f350 diesel. If the diesel was out of my budget I would buy a slightly used 2017 f350 srw diesel.
Being as I have been looking at a new to me truck. A slightly used rig is costing as much or more than some new rigs right now. Granted I am looking at GM 1500's, but from skimming the 25/35 series setups, I see the same issue in higher gvwr rigs.
Usually, if one does not have the funds for a new rig, a one year old rig is usually out of the question. Need to go 5 yrs or older to start getting a significant difference between new and used.
Marty - blt2skiModerator
burningman wrote:
Like was mentioned, it’s a tool you buy to get a job done. It might last longer if it sits in a garage and only carries groceries home every other week, but it’s made for working and it can do it.
Not so sure sitting in a garage is good for too many vehicles, if they sit too long.......My dads 72 Cougar XR7 convertable sat in a garage for so long, it does not run. Rubber, gaskets etc are so shot, it needs a new motor, trans, axels gone thru. Had a cover over it, water got beneath, some things are rusted......has all of 40K miles on it. It would probably be in better shape if it had been driven more than it has been! Worth more too! Overall, it is still clean. still a lot of work to get it ready to drive and enjoy it!
Marty - burningmanExplorer IIWhatever you do, don’t buy any truck yet!!!
You’re about to spend a whole lot of money on something you say you’re completely unfamiliar with (trucks). F250s are not all alike, they can be configured differently.
Spend a bunch of time reading and asking questions here AND on Ford truck forums.
Any new 3/4 ton American truck will pull that trailer, but they can be set up better for hauling heavy depending on options.
Technically, driving the truck at all “hurts” it, like mowing the lawn hurts your mower blade.
Like was mentioned, it’s a tool you buy to get a job done. It might last longer if it sits in a garage and only carries groceries home every other week, but it’s made for working and it can do it. - RCMAN46Explorer
What is wrong with going to 4th gear. It is the same as with going with a 4.30 rear axle in 5th gear.
Rear end gears will not give you more horsepower. time2roll wrote:
No strain. It is just a machine and does not get tired.
Ditto.
It's won't "hurt" either since it has no feelings.- 4x4ordExplorer IIIAn f150 is quite likely a good choice for someone wanting to tow a 10000 lb trailer with a gas engine. If I wanted more truck than a f150 I would buy a f350 diesel. If the diesel was out of my budget I would buy a slightly used 2017 f350 srw diesel.
- Retired_JSOExplorerSkip the gas unless you can find a lower gear than the 3.73. My 16, 6.2 can’t maintain 65 with any headwind over 12-15 mph in 5th towing my 25’ W&P at 9,200 lbs. iI drive in 5th most times towing but a headwind is like putting on the brakes.
44,027 PostsLatest Activity: Apr 19, 2019
