jimh406
Jun 30, 2019Explorer III
If you think you have to buy a new Arctic Fox to get a good one, then I’d mark it off the list.
I think it depends on where you will live/work if a TC makes any sense or not. Apartments are very expensive in larger cities, so is property and there are lots of rules to follow near metro areas.. A fifth wheel is dramatically cheaper per space, but you don’t have a truck. I’d probably consider a used Class A and tow your car assuming your current car is towable. Check for cost of RV spaces per month. The more money you put in up front the more you will lose when you sell/trade. I’d also consider Class Cs/TTs, but again, depends on where you will live/work what makes more sense.
Personally, I’d stay out of Conconully during the Winter. Do some research on climate averages including snowfall. Also, Washington just put into place new gun laws that might/might not be advantage for you, similarly with Oregon. You’ll find climate varies a lot depending on whether you are in convergence zone or not or what side of the Cascades/Rockies you live on.
44,068 PostsLatest Activity: Jun 21, 2026
